Sold WTT 2 2 ch amps (pioneer/mtx) for 1 4 ch
skydeaner
suede humper
I have a pioneer gm-5100t and an mtx thunder-302 that I want to trade for a good 4 channel amp. Any offers please email me at skydeaner@gmail.com or pm me
Here are the stats on the 2 2channel amps
Pioneer gm-5100t
• 2-Channel Bridgeable Power Amplifier
• RMS Power Rating:
• 4 ohms: 125 watts x 2 chan.
• 2 ohms: 190 watts x 2 chan.
• 4 ohms bridged: 380 watts x 1 chan.
• Variable Bass Boost: 0 - 12dB @ 50 Hz
• Speaker level inputs
• Oversized power terminals
• LPF Crossover(80 Hz, -12dB/oct)
• CEA-2006 Compliant
• PWM regulated MOSFET power supply
• S/N Ratio: 75dB
• Frequency Response: 10 Hz - 50 kHz
• Balanced isolator input circuit
• Dimensions: 13"L x 12"W x 2-3/8"H
Thunder 302
RMS Power measured at 12.5 Volts DC:
75 Watts x 2 into a 4 Ohm load with less than 0.05% Thd+N
150 Watts x 2 into a 2 Ohm load with less than 0.1% Thd+N
300 Watts bridged into a 4 Ohm load with less than 0.1% Thd+N
Dynamic Power (IHF-202 Standard) measured at 14.4 Volts DC
120 Watts x 2 into a 4 Ohm load
212 Watts x 2 into a 2 Ohm load
425 Watts bridged into a 4 Ohm load
Signal to Noise Ratio:
110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz ± 0.25dB
Maximum Input:
8Vrms
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 40Hz to 200Hz, 12dB/octave high pass,
24dB/octave low pass with mono output
Dimensions:
9” x 9” x 2” (22.8cm x 22.8cm x 5cm)
10-1/4” x 9” x 2” (26cm x 22.8cm x 5 cm) Including IsoFeet™
You have to put prices. Says so in the rules.
His mistake was not putting this in the WTB subforum.
As he's not wanting to sell his amps but rather evenly swap them for something else, he doesn't have to state a price since he's not looking to sell them but rather evenly trade them for something else.
You're not going to find an amp that has inbuilt crossovers sufficient to run an active setup //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
That's going to have to be done with either onboard HU processing (if your HU has that capability) or outboard in some other fashion...
arc audio amps will do it, and a few others too, I would also like something at least 75x4, I might just have to sell these and buy a 4 ch. A 4ch amp I am looking for will only need crossovers that go up to 3k high and lowpass.
actually I don't really need the crossover point, but something with a little more power would be nice. maybe even a trade for one of the amps and them some cash for someones 4ch that does 75x4 or more
skydeaner
suede humper
skydeaner
Champaign, IL
smd4life
