1. Product: 15" TC SOUNDS TC-2000
2. Specs: Dual 4 ohm
Advanced FEA Motor System
• Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
• 190oz top grade magnet structure
• Anti-flux modulation copper shorting ring to lower distortion
• Low carbon steel used for the gap plate and t-yoke
• Large pole vent for lower distortion and cooling capabilities.
Advanced high excursion soft part system
• Dual high excursion 10" linear roll poly-cotton spiders
• Intergraded woven leads to prevent lead-slap
• 3" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
• Extra spacing in-between spiders for lateral stability
• Single or dual 3.1Ω (4 ohm nominal) voice coil configuration
• Lightweight brushed and powder coated aluminum cone
• 1" wide long throw, highly durable NBR surround
• High quality thermal flexible epoxies to ensure longevity
Patented custom cast aluminum frame
• Extra clearance under the suspension for dynamic high excursions
• Wide spider landings for higher than average throw
• Patented detachable method for easy and fast and recones or repairs
• Durable high gloss black powder coat and chrome vc mesh guards
Performance
• Effective motor force of 98 Newtons2 per watt (BL2/Re)
• 800 watts continuous power (2500 watts peak)
• 28mm BL XMax (voice coil, one-way)
• 41mm XMech (mechanically limited, one-way)
3. Description/Condition: mint condition bought it on 3-10-10, when i recieved it it looked like it had never been mounted. still pretty new.
4. What you are looking for: :15" sub d1 or d4 that can handle at least 1500 rms daily of equal or better value.
5. Pictures of your item for trade: i took these pictures today its still in my car. the bottom pics are from the guy i got it from.
Performance
