WTT: 1200@1 Mono, RF P2, and Wires for...
whitedragon551
Moderator
1. Product:
Cadence Z1200 and XScorpion 2 Channel RCA's
Also have an older RF P2 10" sub
2. Specs:
Z1200 Specs:
Manual Download:
MODEL Z1200 - MONO BLOCK HIGH CURRENT AMPLIFIER - Z SERIES - Cadence Acoustics, LTD
This thing has some pretty beefy internals. Ive read it does 1400@1.
RCA Specs:
* XScorpion Part # 18TR
* High Quality competition grade 2-way RCA Interconnects with gold-plated RCAs
* Triple Shielded and Aluminum Twisted design to eliminate noise from radiating into the system
* Includes Drain Wire that is extremely convenient for grounding RCAs to head unit or ground, which often solves problems with engine noise or alternator whine. The wire can also be used as the remote turn on wire for your amp, which means 1 less wire to run through your vehicle. Drain Wire comes with spade/fork connectors on each end.
* OFC Balanced
* Space Saving Right angle male RCA plugs for plugging into back of head unit
* Outstanding noise rejection, accuracy and frequency response all contribute to excellent
3. Description/Condition:
The Z1200 is near mint. Has a few scratches on the orange plates and some blemishes on the plexi depending on the lighting and how you tilt it.
The amp is 100% functional and sounds great.
RCA's are mint.
P2 Pics and Specs:
http://www.caraudio.com/forum/car-audio-classifieds/477293-rf-p2-old-red-stamped-steel-basket.html
4. What you are looking for: :
Looking to trade both for a 5 channel amp that I can run active on in the front stage and does 500@2 on the sub channel.
Will also look at mono class a/b amps that do 500@2 and a matching active capable 4 channel.
5. Pictures of your item for trade:
Attached
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
