WTT 1/0 to 4ga converters
muskyhunter567
Truck Do Burn Rubber
i need 6 1/0 to 4ga converters, streetwires would be best, but il take P3 or the crappier stuff if i have to, i have (3) 4 inch aero ports from parts express never installed, 3 4ga knukoncepts fuseholders with (2) 150s and a60amp fuse in them, also never installed and i few lower grade scosche and radioshack av cables, so if you need any of that stuff let me know, and thanks ahead of time, and il try and get pics up tonite if you need them
naw i only need singles so i can run1/0 all the way to my amps, i allready have distro blocks, and as a matter of fact, i can also trade 2 streetwires 1/0 in (4) 4ga outs, i think i have all the parts for them, sry bout the mix up
not cut or glued or anything, i found all the parts for one distro block but idk if i have the main screw or the 1/0 terminal for the other one, but il double check, let me know if you need more pics
can i get a pic of those tsunamis?
or do they look like these?
http://www.autotoys.com/x/catalog/0_GAUGE_to_4_GAUGE_WIRE_REDUCER_p_1453.html
Basically, but nickel plated:
muskyhunter567
muskyhunter567
Milwaukee Wisconin
muskyhunter567
