Sold WTS/WTT PA A3000db cheap powerrr
volsfan92
TN
I have a lightly used Power Acoustik A3000db w/ box, bass knob, and papers.This amp was made before PA made their amps cheap.I have recently had problems with the rcas on the amp but its in for repair
Number of Channels 1 - Mono
RMS Power (4 ohms) 1100 watts x 1 channel
RMS Power (2 ohms) 1800 watts x 1 channel
RMS Power (1 ohm) 2300 watts x 1 channel
Bridged RMS Power Not Bridgeable
Total RMS Power Output 2300 watts
Peak Power Output 3000 watts x 1 channel
Total Peak Power Output 3000 watts
Minimum Impedance Unbridged 1 ohm
Minimum Impedance Bridged N/A
THD at Rated RMS Power 0.50%
Speaker Level Inputs Yes
Preamp Outputs 1 pair
Built-in Crossover Low-pass (LP)
Low-Pass Crossover Frequency 50 - 150 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio 100 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
WTT for other amp or cash OBO..I also have an XBOX 360 w/ extras
View attachment 26518797View attachment 26518798
lolz yea this amp is no way does that much power, well not clean n e wayz. Worth maybe 200 shipped
Try again there is multiple tests of this doing over 2000 watts..same board as Planet Audio XD 2250
I will offer this up on trade if you want. Custom built tc3hp hybrid takes 2k all day it's a d2 also. I have it being ran right now at 1 ohm off an a3000db, and I wouldnt mind having another one to strap to mine. You would have to ship first though being that you don't have any refs and I have a ton.
cant beat this
any videos?
any specs? magnet? voice coils?
ive gotten good results out of an a3000 with a good electrical behind. soild 2kw, and the distortion isnt that bad. It sounded just as clean as my kx 2500.1 and wasnt that far behind the kx either. i never got them metered but to the ear the pa was suprisingly close to as loud as the kicker, both at 1 ohm too. this amp is the one, and ONLY product by power acoustik i've recommend to budget 2kw installs on a low budget. worth every penny.
that being said i've bought and sold some for as low as $200 shipped, but typically they're around $225-$250. it sucks having an amp repaired and eventually end up selling it. i've done that more times than id like to remember. i think that tc trade is definitly in your favor if the sub checks out. That's just my take on it man. good luck with the sale.
I'm not the one who built it but it is a tc3hp motor voice coil is a d2. It is one of the best sounding subs I've ever had, and I've had a lot. I have it running in a makeshift box right now 2 cubes tuned tuned at 36 with 32 inches of port. I would run a little bigger of a box and tune around 30-32 but I wanted to get it up and running when I got it so I just built a new baffle for my dual 8 box and used that. I'll gte some video's up later tonight.
Also is it spl based or what?
volsfan92
volsfan92
TN
volsfan92
