wts/wtt Eclipse 36401
Husker
Eclipse 36401
Amp is in good used condition
I have a used Eclipse 36401 4 channel amplifier that is in great working condition. Here are the specs that i found....
*105W x 4 Channel Max. Power Output at 2ohm Stereo
* 60W x 4 Channel 0.1% THD at 2ohm Stereo @13.8V (RMS Continuous Power)
* 40W x 4 Channel 0.1% THD at 4ohm Stereo @13.8V (RMS Continuous Power)
* ChannelFlex Crossover
* Adjustable High-Pass Frequency (50-200Hz, L/R Independent)
* Low-Pass Frequency (120Hz)
* Adjustable Bass-Boost Level (45Hz, 0-9dB, F/R Separate)
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOS-FET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
* Noise Reduction with Low Distortion & Ultra-Low Negative Feedback
* High-Level Input - Add on Capability
* Epoxy Composite PCB
* 2ohm Stable Design....
100.00+shipping
usps
Husker
Husker
Omaha, Ne
Husker
