Sold WTS/FS ***Alpine IVA-W200***
Thetalkingshoe
Oh hay there
Selling for a friend. BNIB Alpine IVA-W200 and I'll include a bypass switch and wire ties and some pig tail connectors.
Spec from Alpine site
FEATURES
Tuner
• HD Radio Ready
• Preset Stations (FM:12/AM:6)
• Auto Memory
• Local/DX Selection
• Preset Address Indicator
• Up/Down Seek
HD Radio™ Ready
• HD Radio Status Indicator
• Automatic Digital/Analog Signal Switching
SAT Radio Ready
• Sirius and XM Satellite Radio Compatible
• Preset Memory, 3-Bands (18 Channels)
• QuickSearch Function
• Category Search
• Text Scroll
Full Speed™ Connection for iPod®
• Dedicated iPod Source Selection
• Direct search function
• Repeat One
• Search Mode Selection (Playlist, Artist, Album, Song Title)
• Shuffle (Albums, All)
CD Player
• 24-Bit D/A Converter
• Zero data Mute (0 Bit Mute)
• Digital Servo
• Music Sensor Up/Dn
• Disc Play/Pause
• Forward/Backward
• Music Search Function
• Dolby Digital/DTS Bit Stream Output
• CD Text, CD Text Display, CD Text Scroll
• MP3 Text Information Display (ID3 Tag)
• MP3/WMA Decoder/Playback
• M.I.X. One (Folder)/All (Random Play)
• QuickSearch Function (MP3 Files)
• CD-R/CD-RW Compatibility
DVD Player
• DVD-Audio Playback (2 Channel mix-down)
• DVD-R/DVD-RW/DVD+R/DVD+RW Compatible
• DVD-Video/DVD-VR Playback
• DTS CD Playback
• Dolby Digital Bit Stream (with 2 Channel mix-down)
• DTS Digital Bit Stream (with 2 Channel mix-down)
CD Changer Control
• Repeat (One/Disc)
• Music Sensor Up/Down
• Forward/Backward
• Disc Play/Pause
• Elapse Time Display
• CD Text Display/Scroll
• Multi-CD Changer Control (with KCA-410C)
• MP3 Changer Ready (CHA-S634)
• M.I.X. One/All (Random Play One or All)
Bass Engine® Sound Tuning
• Subwoofer Level Adjustment
• Bass Center Frequency Control
• Bass Width Adjustment
• Bass Level Adjustment
• Treble Center Frequency Control
• Treble Level Adjustment
(MMStation/Head Units) General
• 1 Aux A/V Input and 1 Aux A/V Output
• 6.5" Widescreen Motorized Monitor
• 50W x 4 High Power Amplifier
• Auto Close/Open Capability
• Rotary Encoder Volume Control (Pop-up Rotary Knob)
• Black Face w/Blue illumination Buttons
• 3 PreOut (2V PreOut)
• Direct Touch DVD Menu Operation
• Bluetooth® Ready
• Data Download
• Visual EQ
• i-Personalize
• Bass Engine
• Subwoofer Level Control
• Steering Wheel Remote Ready
• MM Driver Ready (Hard Disc Drive Ready)
• TDS Amp and Processor Control Capabilities
• Optical Output
• Built-in Dolby Digital /DTS Decoder (2-Channel Mix Down)
• Separate Bass & Treble Control
• Fader & Balance Controls
• Loudness
• S.T.M. (Source Tone Memory)
• Clock
• Dimmer-on Input
• BlackOut Display
• Rear Camera Input
• Dedicated Navigation Input
• Navigation Audio Mix
• Power Antenna Lead
• Remote-on Lead
• Audio Interrupt In
• Wireless Remote Control Included
• Demo Function
• Audio Mute
• CD Changer Control Function
SPECIFICATIONS
FM Tuner
• Tuning Range: 87.7-107.9 MHz
• Mono Usable Sensitivity: 9.3dBf (0.8 μV/75 ohms)
• 50dB Quieting Sensitivity: 13.5dBf (1.3 μV/75 ohms)
• Alternate Channel Selectivity: 80.0 dB
• Signal-to-Noise (S/N): 80.0 dB
• Stereo Separation: 35.0 dB
• Capture Ratio: 2.0 dB
AM Tuner
• Tuning Range: 530-1, 710kHz
• Usable Sensitivity (IEC Standard): 22.5/27.0 (μV/dBf)
DVD Player
• DAC Resolution: 24 Bit (Max)
• DVD Frequency Response: 5Hz-22kHz (+-1dB)
• CD Frequency Response: 5Hz-20khz (+-1dB)
• WOW and Flutter: B.M.L
• Total Harmonic Distortion (THD): 0.03%
• Audio Output Level: 800mV (Fixed)
• Operating Temperature: -10C to + 50C
• Power Requirement: 11-16 volts DC (Negative ground)
CD Player
• Sampling Rate: 44.1kHz
• Signal-to-Noise (S/N): 105 dB
• Frequency Response: 5-20k ±1 dB
• Horizontal Resolution: 500 Lines or Greater
• Channel Separation (1kHz): 85 dB
• Dynamic Range (1kHz): 95 dB
• Total Harmonic Distortion (THD): 0.008% (at 1kHz)
• Number of DACs: 2
• DAC Type: 24-bit D/A Converter
• Optical Output: Toslink (Dolby Digital/DTS/LPCM)
• Oversampling: 8x/352.8kHz
• Wow & Flutter (%WRMS): B.M.L.
Monitor
• Screen Size: 6.5inch Widescreen
• LCD Type: Transparent type TN LCD
• Operation System: TFT Active Matrix
• Number of Picture Elements: 280,800 pcs (1,200 x 234)
• Effective Number of Picture Elements: 99.99% or more
• Display Wide Type: 3 Modes (Wide,Cinema, Normal)
• Subwoofer Level Adjustment Range: -15dB to 0dB (1dB steps)
• Loudness Control at 100Hz (Max): +10dB
• Bass Center Frequency : 60Hz, 80Hz, 100Hz, 120Hz
• Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
• Bass Level Control Range: +20dB to -14dB at 60Hz (2dB Steps)
• Treble Center Frequency: 7.5kHz, 10.0kHz, 12.5kHz, 15.0kHz
• Treble Level Control Range: +-14dB at 10.0kHz (2dB Steps)
Remote Control
• Model Number: RUE-4203
• Dimensions (W x H x D) in: 2" x 4-11/16" x 33/64 "
• Dimensions (W x H x D) mm: 51mm x 119mm x 13mm
• Weight: 50g (1.8oz)
• Battery: 1 x CR2025
Dimensions
• Din Size: 2
• Chassis Size (W x H x D) mm: 178mm x 100mm x 165mm
• Chassis Size (W x H x D) in: 7" x 3-15/16" x 6-1/2"
General
• CEA-2006 Power Rating (4Ohm@14.4 V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
• Max Power Output: 50W x 4
• Pre Output Voltage (Before Clipping): 2V
• Power Requirement: 14.4 (11-16) V.DC
• Operating Temperature ( °C/ °F): +32 °F to +113 °F (0 °C to +45 °C)
• Maximum Mounting Angle: 30° from Horizontal
• Weight: 2.9 kg. (6 lbs. 22 oz.)
Asking 650 + Shipping and paypal 3% if you choose to go that route.
Money orders/Paypal and personal checks accepted. MO and checks will need to clear first before I ship it out.
Fair enough.
How about you buy my dvd player, and I'll buy his.
You can just give hmi the money and send the dvd player my way?...hehe
I just bought a yellow top and I need to buy some wire. Im broke.
Yea thats what I planned on doing. He doesn't really use the internet much.
Thetalkingshoe
Oh hay there
Thetalkingshoe
Chadds Ford, PA
bigballer
