Sold WTS - Custom built 10" 3hp TC sounds motor
Torquem
1. Product: Custom built 3hp tc motor subwoofer
2. Specs:
Vas drive current - 3181.82uA
Revc - 3.5740
Fs - 28.9758
Zmax - 37.7847 ohms
Qes - 0.6792
Qms - 6.5016
Qts - 0.6150
Le - 2.1598 mh (at 1Khz)
Diam - 247.6500mm (9.7500 in)
ConeArea - 48168.8790 mm^2 (74.6619 in^2)
Vas - 51.4815 L (1.8181 ft^3)
BL - 13.5258 N/A
Mms - 190.9724 g
Cms - 157.9784 uM/N
Kms - 6329.9810 N/M
RMS - 5.3477 R mechanical
Efficiency - 0.1778 %
Sensitivity - 84.4983 dB @ 1W/1m
Sensitivity - 87.9976 dB @ 2.83Vrms/1m
3. Description/Condition: 3hp TC motor, Eclipse sw8000 basket modified for QCA, single medium spider, single 3 ohm coil, High roll rubber surround stitched to heavy paper cone, TC sounds aluminum cap.
Some things have come up and I need to move this. I had it built for me and spent 300 bucks to have it done about a month ago. It uses a 3hp TC motor. The eclipse sw8000 basket has been modified to QCA so you can unthread the motor from the basket. I have not mounted it since it was built, but hooked it up to do some free air testing and to show the excursion. This thing is a beast. I'm not exactly sure how to rate condition as this is a rebuilt sub. Mechanically it is 100% with brand new soft parts. Magnet shows a little oxidation, basket has been painted black. Some CA glue showing around the edge of the spider. Cone has no dents but shows some cleaning swirls. I have tons of feedback on multiple forums IE diyma, crsx, gunbroker, etc. Let me know if you have any questions. Thanks!
P.S. - I forgot to mention I have an extra cone that I bought for it that is brand new. I'll throw it in. pics below
4. Price: : $125 plus whatever actual shipping is to you
5. Pictures:
CLICK HERE FOR VIDEO -
Its truly a SQ piece. Not meant for spl. But im sure it will get quite loud in the right box. Just need an amp that does about 1k at 4ohms. Its not about the amount of power you drive into it. Its about the amount of excursion+sd and being in the right box. And this thing has both. over 3" of linear excursion!
Torquem
Torquem
Apex, NC
abrhino
