wtb: what amp to buy
i cant really do that because i have a single cab s-10 and i cant get rid of it i need my passenger seaat and i have the 60 40 beanch so i went with the type s because there not to deep i had 1 sa 12 but it was to deep i was hugging the dash
i would rather buy new and since ive never bought off here before 1 i dont know what to do and 2 i dont trust to many people and also i want to stay in the 2k range i have stock elec but going to do big 3 when i get the amp have everything to do it just need to do it stock alt and batt i was running a alpine mpr 500 and it made my light dim so bad my light s would almost turn off
very understandable
Exile 2400.1 2400rms only 16 inches long and audiocontrol 2xs line driver crossover 300 shipped
i have looked into exile before but there prices on there website are crazy. but for the record for everone i have phoenix gold 3rd octive eq a old skool us amp 425 on my mids and highs with the us amps crossover so i just need the amp
@mylows10 anything you could tell me would be great the truck was my gpas before he died and i dont really want to do a blow through. what do you have for amps that are in my price range and watt range?
Mylows has an actual store so if your buying from he is very reputable if I am not mistaken there is a mini american bass that might work for you
I've bought from mylows10 PLENTY of times. He's a great seller just //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Well pm coming work out a deal for the amp is interested. It's a sick amp and looks great
if your keeping everything stock electrical wise ,then your options will be limited on your truck , the stock electrical cant handle much over 1000 rms with out a alt and battery upgrade .if you takes the stock battery out ,remove the battery tray ,then a group 31 will drop in there .also the alt can be replaced with a direct fit ,no mods with a 200 -250 amp ,takes about 20 minutes to do. run the wires n the pass side thru the firewall and under the seat .the vfl 4480 will be the amp you'll want ,very efficient and small in size.does you 60/40 split bench move up and down like mine did ,if so then theres what you need as far as sub , if the seat works this way ,then a single 10 or 12 behind the pass seat ,ported towards the drivers side would be perfect and if built right can get very loud
i would trust mylows because hes a vender im not new to the website but more of as a member ive came up with a small lits but its not what im limited to more of what comes to mind and imput would be nice so here it is
crescendo 2k
planet audio bb1900
everest soundlabs 1100
hifonics zeus
mb qurt
dd m1c
oh mylows im not sure what you mean about the seat moving up and down it does slide forward and back if thats what you were meaning and im not sure what you meant about the subs and i really want to stay with the 2 12s idea but idk if i want a ported ive always had sealed and im 17 with no job ill start my job may 4th and ill only be working 2 days a week for a while and i might get a batt and alt im not sure and the friday that just passes i was locked up so imma have a few fines to pay so ill be a little tight on money for a little while
yes the seat moving forward and back ,they should move independently ,so if you do a box with sub behind the pass seat then you wont have a mounting depth issue ,and you can run a better sub than what you have now. and make a small amp area to mount the amp behind the drivers seat .port the box facing drivers side ,if done right it will be louder than your 2 12's you have in a sealed box now ,and will take more power as well
send me a pm with a budget for the amp sub and box with wires and i'll see what i can work up for you
2000 watts seems a little overkill for those subs. It doesnt sound like you upgrading cuz of space. You can find a 1000 watt amp for around 250 then put the other 250 towards something else like deadening or a used alt or a top notch enclosure.
big boom crew
big boom crew
valdosta,GA
big boom crew
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
