WTB: USED Efficient, cheap 4 or 2 channel ASAP
I have a Reference Hi-Fi A90 2 channel, built by the same build house as the Massive P series amplifiers.
Does rated power and sounds great doing so.
50.00 shipped.
4ohm RMS power at 14.4V 90W x 2
2ohm Load RMS power at 14.4V 110W x 2
4ohm Bridged RMS power at 14.4V 180W x 1
Input Level 0.2~5V
High Level Input NA
Two Channel Input mode NA
CH-A filter mode HP-FULL-LP
CH-B filter mode NA
CH-A LPF 50~500Hz
CH-A HPF 50~500Hz
CH-B LPF NA
CH-B HPF NA
Frequency Response 10Hz~25KHz
THD at 40hm load 30% Rated Power
S/N Ratio >90dB
Channel Seperation >89dB
Minimum Load 2ohm
Overload protect System YES
ShortCircuit Test@ max power PASS
Overheat protect temperature 80C / 176F
Transparent Isolation Connector NA
HI-END Design NA
Components & PCB SMT & Double side board
Dimension (mm) 198 x 184 x 54
Dimension (inch) 7.8 x 7.2 x 2.1
50.00 shipped.
Input Level 0.2~5V
High Level Input NA
CH-B filter mode NA
CH-A LPF 50~500Hz
CH-A HPF 50~500Hz
CH-B LPF NA
CH-B HPF NA
S/N Ratio >90dB
Minimum Load 2ohm
HI-END Design NA
very interested. Got any pics? and what's the fuse rating?
If you have some 0 ga terminals and a 0 to dual 4 ga distro plus some cash
I do have some 0 gauge terminals, some nice copper ones actually. And I have a 4-way JL Audio 0 gauge distro block. How much cash were you thinking?
Sorry for the delay in photos my phone is having issues syncing with my PC.
But here is what Jacob of Sundown audio had to say about the same amp that I traded in to him during the sundown audio trade in deal a few years back. This was a back up amp I had stored away, tested and works great too btw.
http://www.caraudio.com/forums/car-audio-classifieds-old-replies-only/387736-fs-reference-hi-fi-a90-$75-obo.html
I am going to take some shots with my digital cam and pull them off that way.
okay, well it does at least close to rated. I'm interested to see pics, maybe we can work something out
30a fuse btw.
alec14
alec14
Alpena, MI
alec14
