WTB Subwoofers
http://www.audioque.com/aq/HDCSeries.htm
Guys I am looking for a 15 " d2 driver. I am open to all other sizes as long as the final load is 4 ohm. Looking to spend 150.00. My zip is 27856. Pls post pics up I am looknig more SPL than SQ. It will be in a ported box also no larger than 4-4.5 cu ft. I will have 700 watts to give it, Thanks
http://www.caraudio.com/forum/showthread.php?t=424424
I'll do 150 for ya on the VooDoo, in 3 cubes @ 35Hz with a 3 x 15 x 12.5 port it has 5.26dB of gain giving a 1w/1m of over 90dB meaning wit only 700 watts it would still be darn loud. 118.5dB before cabin gain based soley on gain from power (700 watts = almost 28.5dB of gain from power) Would be hard to get louder for the money.
VooDoo is a hybrid of Crystal Mobile Sound and VooDoo, The cones, Spiders, Surround, etc are Crystal, the frame is the widely available 12 spoke everyone uses and the motors as far as I can tell are a custom tooled version of the Overhung Crystal motor making it a VooDoo exclusive. Suspension wise, look to get 2" of usable stroke. 2.5" if you dont mind a lil suspension noise (spider pulling tight.) Also, later on down the road if you get the SQ bug, it'll do 20Hz all day in 4 cubes @ 22Hz and is stupid flat from 23Hz up with only +/-1dB, and a 3dB down of 19Hz.
Heres the Website: http://www.voodoocaraudio.com/productsSubwoofersVW152D.html
Actual specs of this exact woofer are:
Note these are pre-break-in so Fs, Qts and Qes will drop, Vas and BL will climb slightly through break-in.
Re = 4.2046 ohms
Fs = 27.1756 Hz
Zmax = 74.1004 ohms
Qes = 0.5618
Qms = 9.3397
Qts = 0.5300
Le = 5.1620 mH (at 1 kHz)
Xmax = 16mm (one way)
Diam = 310.0000 mm ( 12.2047 in )
Sd =75476.7656 mm^2(116.9892 in^2)
Vas = 63.2820 L ( 2.2348 ft^3)
BL = 23.6747 N/A
Mms = 438.6239 g
Cms = 78.1968 uM/N
Kms =12788.2451 N/M
Rms = 8.0190 R mechanical
Efficiency = 0.2124 %
Sensitivity= 85.2896 dB @1W/1m
07BronzeFuz
DueceEDuece
07BronzeFuz
Nashville North Carolina
audio_phill
