WTB: SQ Proaudio Mids & Highs
shammyhavik
Seeking a good deal on a pair of QP-TH25 "SuperTweeter" and a pair of QP-MR6.5.
The deal has to be nice.
Whatever else you have to offer is cool and i'll take recommendations
They'll be ran off a PPI900.4 and keeping up with two HDS312's off a SQ2200 roughly 2200 watts.
I look to further upgrade to substage though so headroom is needed
They are dirt cheap to begin with ..looking for a used cheap set of these is like buying used underwear.
There is a post on Craigslist in your area for some Sundown neo 6.5" mids if I were you I would jump on them.
PPI 900 isn't stable up to 8ohm //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
dude it can handle anything 2 ohm and higher. Stability is compromised when you go lower then 1 ohm...
correct. higher impedance loads just result in lower power but benefit from less strain on the amp. to determine power output at 8 ohm loads it's about half the rating at 4 ohms. not an issue with tweeters.
[quote name='shammyhavik']Seeking a good deal on a pair of QP-TH25 "SuperTweeter" and a pair of QP-MR6.5.
I look to further upgrade to substage though so headroom is needed[/QUOTE]
Not exactly soundqubed but still good stuff.
4x Crescendo pwx 6.5 mids and 2x ft1 tweets and more - Car Audio Classifieds
go for the pwx since they are in good condition and ft1s to match em.
have @CSCStang ; setup two 6.5 in each of your front doors ran in parallel, they will be 4 ohms. The FT1 will be on the other channels. He can make it look nice and custom with grills like he did with his ride. This will be loud enough to keep up 2 hdc4 12s on 5k easy. If you ever go any bigger, you can always add another 2 to each door since your amp is 2 ohm stable.
[quote name='Jeffdachef']Not exactly soundqubed but still good stuff.
have @CSCStang ; setup two 6.5 in each of your front doors ran in parallel, they will be 4 ohms. The FT1 will be on the other channels. He can make it look nice and custom with grills like he did with his ride. This will be loud enough to keep up 2 hdc4 12s on 5k easy. If you ever go any bigger, you can always add another 2 to each door since your amp is 2 ohm stable.[/QUOTE]
Edit: the guy said the 4 crescendo mids r pending.. ****. He still has the FT1 supertweets for a pair $70 shipped. Are those better than SQ supertweets for $44/pair?
shammyhavik
shammyhavik
cali
shammyhavik
BP1Fanatic
BP1Fanatic
