Wtb. Small footprint 5 channel
American Bass PH-5100 FR Mini Phantom Series Series 5-Channel Car Amplifier
RMS Power Rating (14.4):
4 ohms: 120 watts x 4 chan.
2 ohms: 240 watts x 4 chan.
Mono Channel 1 ohm: 800 watts x 1
MOSFET power supply with high grade switching devices
LED power/protect indicators
Designed to fit into restrictive or limited spaces while still delivering staggering amounts of power
Ultra efficient Nano Technology power supplies and endless possible installation scenarios
Extreme power in a small footprint
Ultimate mounting flexibility (stackable, line array, side mount)
Mill Spec double sided PCB with SMD parts
Built-In noise reduction circuitry
Heavy duty aluminum alloy heatsink anodized in a Raven Black finish for extreme heat dissipation
3-Way protection circuitry (short circuit, overheating and Low Voltage)
Chrome-plated RCA level inputs
Chrome-plated screw terminals
Adjustable high-pass filter (40-200 Hz, 24 dB/octave)
Adjustable low-pass filter (20-200 Hz, 24 dB/octave)
Frequency response: 20-25,000 Hz
THD (Total Harmonic Distortion):
Signal-to-Noise Ratio: >89 dB
Max Voltage: 15V
Max RCA Voltage: 5V
4-gauge power and ground wiring is required for installation.
CEA-2006 compliant amplifier
Weight: 15 lbs
Dimensions: 15"L x 5-1/2"W x 2-1/8"H
1 Year Warranty
Max Voltage: 15V
Max RCA Voltage: 5V
Weight: 15 lbs
1 Year Warranty
Not bad at all. Just as long as my Eclipse is now but at half the width just for a little extra height? OP, that'd be a solid choice. Good seller, too.
timhof13
timhof13
Michigan
timhof13
