WTB: Inexpensive 150W-200W RMS Small Footprint Amp
i got a diamond audio d3 400.1 ill let go for 100 shipped... its a nice little amp... http://www.onlinecarstereo.com/CarAudio/p_19464_Diamond_Audio_D1_4001.aspx
RMS Power @ 2 Ohm: 400 Watts x 1
RMS Power @ 4 Ohm: 200 Watts x 1
Pulse Width Modulated (PWM) MOSFET Switching Power Supply
Extruded Aluminum Heatsink
Nickel Plated RCA Low Level Audio Inputs
Nickel plated, low resistance power and speaker connector blocks
Power ON and Protection LED Lighting for Easy Diagnostics
Thermal, Short Circuit, and Overload (Low Impedance) Protection
6dB bass boost
Chassis mounted ATC/ATO type automotive fuses
Class AB Amplifier Topology
Internal 12dB/Octave Low Pass Filter (40-250Hz)
Bass Boost EQ (0 to +6dB) at 50Hz
i got a diamond audio d3 400.1 ill let go for 100 shipped... its a nice little amp... Diamond Audio D1 400.1 400 Watt Monoblock Amplifier at Onlinecarstereo.com
$100 is more than I am willing to spend for this little project. Thanks though!
i have this in good shape:http://manual.kenwood.com/files/B64-1357-00.pdf
rated at 120@4ohm and 160@2ohm. Has a 25amp fuse. I used it for a set of jbl 8's ported and it was impressive for a small setup
you can have it for $20.00. Just pay shipping
Interested. Shipping quote to 26105?
i would use usps flat rate shipping box, packaged safely. whatever they charge now. $15-17 i think. I can also send you pics of the amp once Im off. 336-624-7277, text me and i will reply with pics. Will be around 6:00 this evening.
Hey Big Scott sorry my budget is too small for you. This is for a power wheels jeep. Not a car. If you have a free one to give away I'll let you know a place you can put it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif. I measured this evening and the size constraint for this are 11" x 10". With the 11" sides being available for the inputs and outputs.
you can put my **** in your mouth.
you can take that power wheel and shove it up your ***
prick.
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
542
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
  • Locked
I can get this to somewhere in NJ in US. Is that possible for you to ship that out ?
cas0586
cas0586
WV
cas0586
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
