[WTB] HU, Amp, stuff for budget install
jfrosty42
Product I'm looking for:
HU
Rear USB - not front.. both would be okay
Aux (front or rear)
3 pairs of RCAs
The ability to control my ipod from the ipod via USB
Decent EQ - 5+ parametric preferably
HP & LP
Amp
5 channels
40+ x 4 @ 4 ohms
250+ x 1 @ 2 or 4 ohms
Subsonic would be nice
Bass knob
Install Accessories
Spare pieces of deadener and maybe some thin pieces of foam for in between panels
Budget:
Cheaper the better - this will be an extremely budget setup
HU - $100ish
Amp - $120ish
Condition:
Working 100%
*** I have plenty of iTrader on DIYMA under the name 'jfrosty42'. ***
Rear USB - not front.. both would be okayAux (front or rear)
3 pairs of RCAs
HP & LP
thanks though
i have 20 ft rca's ,also have some 8 gauge wire 2 distro blocks and 2 midi fuse blocks and fuses
I have an Alpine CDA-105 that's in great condition. It was in my son's car and bought a new one and decided to use the factory head unit. It has everything you need and, I think I may have an ipod adapter for it somewhere that allows you to control the ipod from the head unit. The only problem with it is that the USB connector got damaged when I removed it from where we had it epoxied to the dash kit. I will replace that cord and, replace it with a longer one if you like. I'll also post a video of the repair and it working properly. Fixing it is something I have to do anyway, so might as well get it done. Also... it will either come with the aux adapter or the ipod adapter. You can use both on these units but they aren't integrated, so it's a cord you have to buy. Newegg sells it for ten bucks. As for the ipod adapter I think it's a bit higher and like I said, I may have one that I can ship with it.
I'll take $100.00 for it shipped domestic US.
Do you know if the ipod can be controlled from the ipod when hooked up via usb? This is important because I can't stand using the deck to scroll through music.
I need to verify that with my son but, I think that you can control it from either when it's connected via the iPod cord and only the iPod when connected via USB. The iPod cord does not connect to the USB, btw.
jfrosty42
jfrosty42
Golden, CO
bbeljefe
