WTB: Electronic Crossover, Audio Control, ARC Audio, eyc.
I've got a BNIB PPI X3 2/3 way electronic with external bass controller.
Pic can be seen here: http://img401.imageshack.us/img401/1331/ppix3de8.jpg
Asking $125 OBO.
Specs:
S/N Ratio >102dB
THD(1KHz, 1VRMS) 0.01%
X-Over slopes 12dB/octave Butterworth
X-Over freqs.
Front HP 50Hz-8KHz (X10 switch)
Rear HP/BP 50Hz-8KHz (X10 switch)
Subwoofer 5Hz-800Hz
High level input voltage 2-7.5V
Low lever input voltage 150mV-2.5V
Max. Output (10K ohm load) 4V
Supply Voltage 9-15VDC
Dimensions 6 3/16W X 6 7/8L X 1 1/4H
I didn't get your PM.
OK, I sent it this time.
Mr. C,
That US Amps is sexy! I have seen some pics around the net ...if you have some nice pics send them to me or post them. I will do a little more research on it. I saw the specs from their site...seems like a very nice unit. Are there any other specs listed than what is here? http://www.usamps.com/products/inv/us-x3.htm
Walt
wldock@hotmail.com
OK, I found more specs..VERY NICE!
US-X3
• 3-Way Electronic Crossover
• Switchable for 2-Way Operation
• Two Channel High Output:
12dB per Octave High-Pass
Continuously Variable 500Hz-5KHz
Variable High Output Gain
• Two Channel Mid Output:
12dB per Octave Low-Pass (3-Way Mode)
Continuously Variable 50Hz-500Hz
Variable Mid Output Gain
• Two Channel Low Output:
Variable Low Output Gain
Up to 20dB Boost at 53Hz
Switchable Phase Inversion
Can be Switched to Second Input
• 9 Volt Preamp Outputs
• THD at Rated Output:
• Signal/Noise Ratio: 115dBA
• Dimensions: (Including Terminals)
33mm / 1.32in High
242mm / 9.5in Wide
165mm / 6.5in Deep
• Weight: 0.91kg / 2.0lb
• Clear Plexiglas Cover
WLDock
WLDock
Michigan
WLDock
