WTB distribution blocks and battery terminals
thanks guys for the kind words
I have 1 pair made up that clamp down they are 6X0/1 but can easily use 4 g as well .
So you put your battery terminal thru the big opening on the block and then use bolts for your runs to your amps or whatever else needs connected to your battery? What secures the battery terminal to the block? Do you have any smaller blocks, like one that just has 3-4 spots for connections? Do you make fused distrobution blocks? I need a fused block that has two 4ga. in and two 4ga. out using ANL or mini ANL fuses.
gizmo36
gizmo36
charlotte NC
HomeGrown
