WTB Custom Box 2007 Tacoma Double Cab, Single IDQv3
benchambers80
Banned
I need something like this without the amp rack.
Or Like this
5.75 inch mount depth.
Here are some measurements
Please PM me or Post here if you are able to build/sell one of these enclosures.
Laredo, Ive seen some on ebay but they lack the 5.75 depth requirements, but I can hack something if need be. Please let me know exactly what you can get me. Thanks //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
You can remove that rear brace with a spot weld drill bit....reason for the notch in the box back...It only takes about 30mins of time...i removed mine then deadened the whole back wall....with that removed it will make a much easier box to build plus give you more air space for your sub....
Yea I will ask, I may request a larger slot port. The box is built to order over at Diyma by Mr.Marv. He asked what I had in mind, I like this one and may make some changes.
well if thats the case ...Im sure an individual building them can get you what you want...and he would know specs...I thought it may of been some prefab where they slap a hole in the side and call it ported...Like I also said if remove that brace...you can make it a much easier box to build and gain airspace...the box will cover the rear wall...so you won't see it...youll still need the lower notch for the seat hinge though
benchambers80
TX
benchambers80
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
