Nautic Series 4-Channel Class A/B Marine Amplifier
Max power output: 360 watts
RMS Power Rating:
4 ohms: 60 watts x 4 chan.
2 ohms: 90 watts x 4 chan.
Bridged, 4 ohms: 180 watts x 2 chan.
MOSFET PWM power supply
UV and salt water resistant paint, silk screen and heat sink enclosure
Marine-grade conformal coated circuit boards resist corrosion from salt spray and moisture
Non-corrosive brushed aluminum casing
Conforms to the American Boat and Yacht Council (ABYC) marine electronic standards
LED power and protect indicators
Bass Boost (0-6 dB bass boost at 45 Hz)
2/1 channel operation
Full range line outputs
4-Way system protection circuitry (DC, short, thermal, overload)
Heavy duty aluminum alloy heatsink
Gold-plated RCA level inputs
Gold-plated screw terminals
Variable high-pass filter (40-250 Hz)
variable low-pass filter (40-250 Hz)
Frequency response: 10-4,000 Hz
Variable input level control (0.2V-6V)
Damping Factor: 180
Dimensions: 12-5/8"L x 9-1/2"W x 2-1/8"H
125 shipped
1 yr warranty
