WTB: Amps(s) > 400 RMS x 2 @ 4 ohms.
Sarthos
MN
Title says it all. Looking for either a 4 channel amp that can do AT LEAST 400x2 RMS @ 4 ohm bridged, a 2 channel amp that can do 400x2 RMS @ 4 ohm, or a pair of matching mono amps that can each do 400x1 RMS @ 4 ohms. Not 400 max, 400 RMS. Preferably at least 500 RMS so I have some decent headroom. Or a single Planet Audio TT2250D, I already have one I'd make a pair with them.
Running a pair of subs, so amps that only output subwoofer frequencies are fine. I don't want anything crappy (like cheap sony xplod stuff) I'd prefer something like a good Eclipse or something.
What's the condition on it? And do you have a birthsheet? The manual says 345 x 2 RMS @ 4 ohms, ebay ads say 700x2.
I guess you'd be the person who might have one of these, would you happen to have an older Planet Audio TT2250D? That could also be used since I have a second one to make a pair.
I don't have the birth certificate but here is a 175.4 birth certificate for another amp....mines a 8.5-9/10 looks...Its really nice
but the amp has 2 40 amp fuses...how can it do 702 RMS x2? *scratches head*
I also thought the 175.4B was a class D amp but the birthsheet says A/B?
The lack of consistency between any two sources talking about this amp is why I've always thought about running one (actually for an active front stage) but never did.
but 2x40 amp fuses=80 amps. 80 amps x 13 volts (testing voltage) = 1040 watts. Even at 14.4 volts it's only 1152 watts.
It may just be that the manual is massively underrated.
How "used" is it? Just wondering cause there's refurbs on fleabay for 135. :/
I know this is gonna sound like a fail on me, but i'm not particularly familiar with the quality on the fusion brand.
I have a DD S2
390x2@4ohms
1100x2@1ohm
2200x1@2ohms
DD usually tests their amps at 10.9v so power at 14.4v would be above 400 per ch at 4ohms, it's class A/B also.
Sarthos
Sarthos
MN
Sarthos
