WTB: amp that does 125-200rms x2 @ 4ohm
ive got a volfenhag amp that does 125x2 @4 ohms... ill take 100 shipped for it
but then id have to get another amp //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
I dont think they make a xenon 400.2 or at least it's not on their website.... What are the specs on that xtant??
@ 4 Ohms 2 X 50
@ 2 Ohms 2 X 100
@ 4 Ohms Bridged 1 X 200
Freq. Response: 5 to 50kHZ +/-1dB Distortion (THD): Signal to Noise Ratio: >100dB
Input Sensitivity: 40 dB of available sensitivity, adjustable in 10 dB steps.
100mV to 8.5 Volts (unbalanced source)100mV to 17 Volts (balanced source)
Regulated, PWM Operational
11 to 15 Volts
30 Amp fuse
It also has a 12db lp modulator chip inside and you can take it out if you want. need pics? let me know
I have a 4 channel PG Tantrum 400.4 that may work. Bridge it, rated @ 200 x 2 rms @4ohms bridged. Birthsheet states 230 x 2 rms @4ohm bridged. It'll be exactly what you need, just use RCA y-adapters if needed.
$175 shipped.
NG
Nine.2 sounds good but you only have three posts....PG sounds GREAT just dont know how to bridge it so i get stereo output...Anyone else have offers???
Easy as pie. Take one pair of RCA's, use Y-adapters (one male to two female). Run Left side on channels 1+2 (Plug in single white RCA w/ y-adapter to it). Run Right side on channels 3+4 (Plug in single red RCA w/ y-adapter to it). Now you're set //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
NG
txred0810
txred0810
Huntsville, TX
exmaxima
