WTB:: Amp for Components. 125W-150W x 2 Strictly
it is brand new in the box with warranty from sonicelectronix... only place that would end up being cheaper would be millionbuy and i wouldnt touch them with the long end of a stick. with shipping and everything cost me like 170ish... would save you $20 and help me out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i'd do 150 shipped just dont want to lose all my money
I'd sell you my Zapco Z150S2 for $200 shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif .. little bit more than you want to spend but its a better quality amp than all that is posted.. nothing like the good ole cheater amps that usaci cracked down on haha
Specs on my Zapcos.. make me an offer
Zapco MODEL Z100S2
2 x 50w rms
Specs:
Power/Mode
130 watts @ 4 ohm Stereo .02% THD
190 watts @ 2 ohm Stereo .04% THD
190 watts @ 4 ohm Mono .04% THD
Frequency Response 20-20kHz
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 40 V/uS
Damping Factor 300 @ 4 ohms
Input Sensitivity .25-2.5 volts
Power Requirements 22amps, max, @ 2 ohm
Fuse Internal, 30A
Minimum Load 2ohms Nominal Stereo, 4 ohms nominal mono
Idle Current .8A
Dimensions 10.25"x6"x2.25"
Zapco MODEL Z150S2
2 x 75w rms
Specs:
160 watts @ 4 ohm Stereo .02% THD
250 watts @ 2 ohm Stereo .005% THD
250 watts @ 4 ohm Mono .04% THD
S/N Ratio 110dB
T.I.M. .002%
Seperation 65dB
Slew rate 50 V/uS
Fuse Internal, 20A
Idle Current .85A
hey iv got a nice viper 400.2 does 125x2@4ohm its made by directed so its a soild amp. and im running it with rainbow slc;s right now and it sounds awesome with them. im just changing amps up because im going active hows 125 shipped sound. PM me and ill get you some pics and ref's and stuff.
Kicker Kx150.2 $55shipped? Probably the cheapest, nicest brand you can find //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif PM ME!
Practically brand new, works perfect, birth sheet said it does 220watts @ 4ohms @ 14.4volts. So i would assume it does around 110w x 2
# 2-Channel KX-Series Power Amplifier
# Low Impedance Operation
# SORT Protection Circuitry (Short circuit, Over-voltage, Reverse polarity, Thermal)
# MOSFET Power Supply
# KickBass: 0-18 dB @ 45 Hz
# Built-In Variable Crossover: 12 dB High or Low-Pass operation (50-200 Hz)
# High & Low level inputs
# PAST (PRE Amp Signal Transfer) Output RCA jacks
# Custom tooled gold plated connectors
# SAMS (Stereo And Mono Simultaneously) bridged mono load and a stereo load at the same time
# Cast aluminum EndKaps
# RMS Power Ratings:
* 14.4V:
o 60 watts x 2 chan. @ 4 ohms
o 75 watts x 2 chan. @ 2 ohms
o 150 watts x 1 chan. @ 4 ohms
* 12.5V:
o 30 watts x 2 chan. @ 4 ohms
o 60 watts x 2 chan. @ 2 ohms
o 115 watts x 1 chan. @ 4 ohms
# Input gain control: Low Level (170mV - 5V), High Level (340mV - 10V)
# Dimensions: 12-3/4" L x 10-1/8" W x 2.5" H
__________________
chibahawk
oe squeezer
chibahawk
NYC
Hintzyboy
