WTB: 4 Channel Amps
Eazyryder136
NC
I am looking for a really large 4 channel amp. I have been looking at the Cadence ZRS1004 and the Arc Audio KS300.4 but open to any other options you guys might have or recommend...
I need to run two speakers off it that run 200 RMS @ 4ohms and one speaker that bridged at 300RMS @ 4ohms. It will be going in a compartment underneath a seat in my boat so I am really looking for amps that are good at staying cool.
Just let me know what you have.
Thanks,
Chris
I've got an Arc Audio KAR 400.4 that I would sell for $185 shipped. This thing stays pretty cool as I had it installed while living in Arizona and it never missed a beat.
Specs:
Output power : 50x4@4 ohms, 100x4@2 ohms, and 200x2 4 ohms bridged
Transient distortion :
Frequency response: 20Hz-20Khz
S/N ratio(A wtg) : > 95dB
Bass boost : + 18dB @45Hz
Input sensitivity : 250mV - 2.5V
Crossover : 55Hz-5.5KHz variable 12dB
Fuse :
40A x1
Dimensions : 13" x 8.5" x 2.5"
This is perfect for your application I got a JL e6450 6 channel amp. does 75x6@4ohm or you can bridge channels
1-2 bridged you will get 250 @ 4ohm
3-4 bridged you will get 250 @ 4ohm
5-6 will do about 300 bridged since it is the sub channel
This is perfect for your application I got a JL e6450 6 channel amp. does 75x6@4ohm or you can bridge channels1-2 bridged you will get 250 @ 4ohm
my e6450 does not have sub channels //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Measured Power (CEA-2006 Standard): 72.7 Watts x 6 into 4 ohms; 107.8 watts x 6 into 2 ohms; 215.5 watts x 3 into 4 ohms
Sub Channel only (Channels 5 & 6 at 50 Hz): 107.6 watts x 2 into 4 ohms; 181.6 watts x 2 into 2 ohms; 363.3 watts x 1 into 4 ohms
Jmanpc: thanks..but I need something bigger
Robert: thanks..but I need something bigger
Hoss: Thanks. but I dont want to put that much into it.
Sonic Purity: thanks..but I need something bigger
Mazzasec: Thanks.. but sorry I dont need a 6 channel
Please keep them coming though..
Good luck finding a 4ch amp with the specs you are looking for especially a class A\B amp. There isn't too many amps that are like that. Maybe try a Alpine PDX-4.150 or get 2 2ch amps
ANyways,
Soundstream Van Gogh 500.4 Class A/B Amp Engineered by Karl Cummings
125x4 @ 4ohms
250x4 @ 2ohms
500x2 @ 4ohms Bridged
Eazyryder136
Eazyryder136
NC
mavssolja
