M Magz_rule 10+ year member Senior VIP Member Rating: 0% 0 0 0 258 0 ny Sep 11, 2008 #1 Looking to buy a decent 4 channel amp. Nothing real expensive, post what you have..Thanks! Click to read more...
M mike70wu 10+ year member Senior VIP Member Rating: 0% 0 0 0 260 0 Here Sep 11, 2008 #2 4 channel jensen 600 50 shipped
Slammed 5,000+ posts Striking Accord Rating: 100% 1 0 0 31,250 169 Gotham City, NY Sep 11, 2008 #3 I will be getting a Brand New JBL GTO75.4II Amplifier soon it does 104 watts RMS x 4 (but its underrated) $130 Shipped //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
nismos14 5,000+ posts CarAudio.com Veteran Rating: 100% 4 0 0 14,812 4 Jersey Sep 16, 2008 #4 $175 shipped RMS Power measured at 12.5 Volts DC: 37.5 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N 75 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N 150 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC 85 Watts x 4 into a 4 Ohm load 140 Watts x 4 into a 2 Ohm load 280 Watts bridged x 2 into a 4 Ohm load Signal to Noise Ratio: > or = 110dB A-Weighted Damping Factor: >200 Frequency Response: 20Hz-20kHz±0.25dB Thunder EQ: Variable Bass Boost (0-18dB) centered at 40Hz Crossover: Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable Dimensions: 13" x 9" x 2" (33cm x 22.8cm x 5cm) 14-1/4" x 9" x 2" (36.2cm x 22.8cm x 5cm) Including IsoFeet(TM)
3 350zspl 10+ year member CarAudio.com Veteran Rating: 100% 8 0 0 4,241 11 WPB Florida Sep 16, 2008 #5 crunch gp4100 crunch gp4150 brand new $ 105 shipped gp4150 $ 95 shipped gp4100
