WTB: 4 channel amp
Pitchblack98
I am looking for a 4 channel amp to run a set of front components and a single 10" Rockford Fosgate DVC sub (old school). Let me know whatcha got or recommend one that will run everything good.
This will all be run off of a Nissan Fosgate factory CD changer deck so a built in crossover would help greatly. If not, I have an external crossover I can use.
Anyone interested in trading (2) 2 channel amps I was going to use. I just dont have room to install both of them so a single 4 channel suits my needs better. One is a Kenwood KAC-729s and the other is a Power Acoustik PA2-1200.
Here are the specs...
PA2-1200
2 Channel
2 ohm stable
250x2 @ 4 ohm rms
300x2 @ 2 ohm rms
600x1 @ 2ohm rms
1200 peak bridged
20.5” x 11.25” x 2.25”
KAC-729s
2-Ohm Stable
Power Indicator
Screw-Type Power and Speaker Terminals
Speaker Relay Protection
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 100W x 2 @ 14.4V
THD at 4-Ohm RMS Power: 0.08%
Bridged RMS Power @ 4 Ohms: 300W x 1 @ 14.4V
Speaker Level Inputs: yes
Preamp Outputs: no
Built-In Crossovers: HP/LP
Bass Boost: 0
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: 100 dB
Fuse Rating: 2x20 amps
Let me know if anyone is interested and I can get some pics for you. That MK800.4 or the memphis amp would work perfect for me. The clarion might be a little small for my needs.
Do you have any pics of it? Also what are the specs on it and the measurements on it (Length, width, and height). I can't find anything on it on line or on US amps site.
What do you want for it?
Pitchblack98
Pitchblack98
Littleton, CO
profoundwill
