WTB: 2 channel SQ amps
Jake Papa
C55 AMG
Hey guys...
Im looking for some high powered SQ amps to run my front stage. I need ~175-200rms x2 @4ohm. The brands im looking for are MMats, Tru, Zapco comp, Mcintosh, DLS, etc... Looking to spend under $700 so if your looking to sell anything ill be interested in PM me.
PLEASE PM ME! Dont reply to the thread because there is a good chance i wont check it very often. Thanks.
Very interested in the Mcintosh Mc440M. We might have to work on the price a little if your willing. Also if you could post pics of it in the thread, that would be great.
I replied to the PMs that im serious about. If i didnt reply im sorry but im not interested.
Thanks for all the PMs! Ive never seen so many so fast..hah
Also that amp i just told u bout i had even has a crossover module in the bottom of it that you can change it even if you want also. The amp is made in italy.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Man the output on this one is good & also under rated here's what they do
Output Power at 11 to 14.4V:
2 x 120W @ 4 ohms
2 x 200W @ 2 ohms
1 x 400W @ 4 ohms bridged
Efficiency: >60% (at 11V, 4 or 2 ohms)
Freq. Response: 20Hz ∼ 60kHz (-3dB)
THD:
IM Distortion:
S/N Ratio: >95dBA
Damping Factor: >500
Max. Current: 38A
Fuse: 40A
Dimensions: 11.4" x 8.2" x 2.1" (28.9cm x 20.7cm x 5.2cm)
Weight: 5.8 lb. (2.65 kg.)
Even if it does 150x2 @ 4ohm its not enough. The PPI was doing more than that and not pushing them to the fullest...
Just to let you guys know what im running its 2 Hertz 6.5"s, 1 3", and 1 tweeter on each side. Its not a simple 2 way.
Jake Papa
C55 AMG
Jake Papa
St. Louis/ASU
Jake Papa
michigan born
    May 14, 2026
michigan born
    May 14, 2026
