Wtb 2 channel or mono amp
Product I'm looking for: A 2 channel or mono block ampSomething like a hifonics would work 600+ rms 1 ohm stable is a + also
Budget: 130
Condition: used
Time Frame (if applicable): asap
How about a used, in good condition Interfire IFH-2150 high current amp? Here's the specs:
Number of Channels 2
Max Power 1500W W
Max @ 2 Ohm Mono (14.4V) 1500 x 1
Max @ 1 Ohm Stereo (14.4V) 750 x 2
RMS @ 1 Ohm Stereo (12.5V) 500 x 2
RMS @ 2 Ohm Stereo (12.5V) 250 x 2
RMS @ 2 Ohm Mono (12.5V) 1000 x 1
RMS @ 4 Ohm Mono (12.5V) 300 x 1
RMS @ 4 Ohm Stereo (12.5V) 125 x 2
Signal to Noise Ratio 112dB
Bass Boost (45Hz, Variable) 0-18dB
Damping Factor (4 Ohm) >900
Fuse Rating 2x40 Amp
Idle Current 0.6 Amp
THD (@ 4Ohm) 0.004%
Line Level Output Yes
Crossover Frequency 40Hz - 2kHz
(Low/High-pass) variable
Dimensions (L X W X H) 13 3/4" x 9 4/5" x 2 1/3"
Can do $130 shipped Priority Mail.
on1wheel01
Bang A Lang
on1wheel01
Mooresville nc
on1wheel01
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
