wtb 2 3k .5ohm stable amps or 1 6k@1ohm
$475 shipped
The RD series amplifiers deliver a ton of power with a low distortion rate. We used the best parts we could find to give you a top quality amplifier that anyone would be proud to show off. With their clean looks and sleek finish, they’ll look good in any install. So whether it’s an elegant sound quality setup or a high powered SPL vehicle, the RD series amplifiers have you covered.
Features
Digital class-D linkable mono block amplifier
MOSFET PWM power supply
Daisy-chain through output RCA
Double sided through hole epoxy PCB
Stable into 1 ohm and 2 ohm parallel amplifier connection availability
24dB/oct variable crossover
Variable subsonic filter
Variable bass boost
Variable low pass filter
Variable phase shift
Efficiency : 86% @ 4 ohm, at 100Hz
Multi-way protection circuitry (Thermal/over current/speaker short/speaker dc protection)
RCA line input
Tested voltage & THD : 14.4V & less than 1% THD
Operating voltage : DC 10V~18V power input- 2008 models
Wired remote controller
MSRP
$1399.00
Specifications
RMS power, 2 ohm linkable/dual mono 5600w x 1ch
RMS power, 0.875 ohm mono 3750w x1ch
RMS power, 1 ohm mono 3000w x1ch
RMS power, 2 ohm mono 1500w x1ch
RMS power, 4 ohm mono 750w x1ch
Signal to Noise Ratio >100dB
Low pass frequency crossover 35Hz~300Hz
Subsonic filter 10Hz~60Hz
Bass boost @ 45Hz 0~18dB
Phase shift control 0~180 degree
Frequency response 10Hz~350Hz (+/- 1dB)
T.H.D @ 4 ohm
Efficiency @ 4 ohm 86%
Fuse rating 300A(external type fuse - not included)
Input Sensitivity 200mV to 6V (+/- 5%)
Dimensions 222(W) x 52(H) x 590(L)mm
Manual: RD Audio - Coming Soon
As title says....need to power 2 sundown zv418s d1.On a fairly tight budget so just let me know if u have anything.
And please dont wst my time telling me to save up to get a good amp...i have 500 roughly to work with.
Is $500 per amp. Or for both amps to achieve 3000 watts?
Yeah i spent the majority or the day/night researching....had 4 possibilities... The ta had a LOT of complaints overheating. So it was out.
Then there was 2 apsm1500's strapped at .5 will do a decent bit over 3k clean and 4k dirty.....but ap im not a fan of and revoews were 50/50. Some ran .5 not issues, others went up in smoke at 1ohm.
Then the rub1.2500, seems from what i read it is def better than the ta and i personally know a guy runnin 4, 2 strpped to each hdc4 18 and he has no issues ever and they do close to 3500 clean at .5
And then thetes what i ordered...the ppi ba7000.1d....does clean 3k and is a beast for the moneyband .5 stable....except its on **** backorder for a month!
So cancelled and ordered the rub1s.
I should easily be able to get 3k per sub at .5 with them.
My elec is on point so not worried bout overheating. 2x300amp alts, kinetik hc3800 under the hood and 2 ns170ft in the back, 4 runs 0gauge, big 3...so yeah i think ill be fine and 6k CLEAN for 500ish cant be beat!
The soundstream rub2500.1 at .5ohm doesn't do anywhere near 3500rms clean, strapped Yea but not one alone. They are dirty at .5ohm I've ran one for a short period of time and clamped 2100 rms At .5ohm. Did better at 1ohm, cleaner power and not such a current hog. There is a guy on caco selling 2 addictive audio 200.1's
Man, I hope you find what you are searching for. It is deff worth the time spent for something you always want back or wanted period.LOL I was...
488
  • Locked
COMPLETED WTB Eclipse SC8365
I checked at Diyma and I signed up for an account but I cant post in the classifieds. Thanks for the tip, I'll keep a check there.
  • Locked
I can get this to somewhere in NJ in US. Is that possible for you to ship that out ?
plexlove
plexlove
missouri
Jeffdachef
slater
    May 2, 2024
slater
    May 2, 2024
