write caching? computer help
truz05
NY
i've read about this a little bit, but all I really know is that enabling it on your hard drive makes things much quicker, but the price is the possibility of data loss in the event of power loss, etc.
I dont have a battery backup, how risky is enabling it, when would the data loss actually occur?
thanks
yep, you're actually right. my C drive is already enabled
but what about for an external USB hard drive? Western Digital 160gb
what do you think of enabling write caching on that?
you are only going to save a few milliseconds each time you access the storage drive so unless you access the drive constantly it wont matter and since it is a storage drive you probably dont
Caching reads from the hard disk and caching writes to the hard disk are similar in some ways, but very different in others. They are the same in their overall objective: to decouple the fast PC from the slow mechanics of the hard disk. The key difference is that a write involves a change to the hard disk, while a read does not.
With no write caching, every write to the hard disk involves a performance hit while the system waits for the hard disk to access the correct location on the hard disk and write the data. As mentioned in the general discussion of the cache circuitry and operation, this takes at least 10 milliseconds on most drives, which is a long time in the computer world and really slows down performance as the system waits for the hard disk. This mode of operation is called write-through caching. (The contents of the area written actually are put into the cache in case it needs to be read again later, but the write to the disk always occurs at the same time.)
When write caching is enabled, when the system sends a write to the hard disk, the logic circuit records the write in its much faster cache, and then immediately sends back an acknowledgement to the operating system saying, in essence, "all done!" The rest of the system can then proceed on its merry way without having to sit around waiting for the actuator to position and the disk to spin, and so on. This is called write-back caching, because the data is stored in the cache and only "written back" to the platters later on.
Write-back functionality of course improves performance. There's a catch however. The drive sends back saying "all done" when it really isn't done--the data isn't on the disk at all, it's only in the cache. The hard disk's logic circuits begin to write the data to the disk, but of course this takes some time. The hard disk is using a variant of that old "the check is in the mail" trick you might hear when you call someone to remind them of that loan they were supposed to pay back three weeks ago. :^)
Now, this isn't really a problem most of the time, as long as the power stays on. Since cache memory is volatile, if the power goes out, its contents are lost. If there were any pending writes in the cache that were not written to the disk yet, they are gone forever. Worse, the rest of the system has no way to know this, because when it is told by the hard disk "all done", it can't really know what that means. So not only is some data lost, the system doesn't even know which data, or even that it happened. The end result can be file consistency problems, operating system corruption, and so on. (Of course, this problem doesn't affect cached reads at all. They can be discarded at any time.)
Due to this risk, in some situations write caching is not used at all. This is especially true for applications where high data integrity is critical. Due to the improvement in performance that write caching offers, however, it is increasingly being used despite the risk, and the risk is being mitigated through the use of additional technology. The most common technique is simply ensuring that the power does not go off! In high-end server environments, with their uninterruptible power supplies and even redundant power supplies, having unfilled cached writes is much less of a concern. For added peace of mind, better drives that employ write caching have a "write flush" feature that tells the drive to immediately write to disk any pending writes in its cache. This is a command that would commonly be sent before the UPS batteries ran out if a power interruption was detected by the system, or just before the system was to be shut down for any other reason.
yes, I read this, but beyond this article, I wanted to know about write-caching and its popularity. basically whether or not I should enable it on my music drive...
i dont use it on my backup drives, i just keep them defragged
if you can play the music or whatever fine with no buffer under runs and there isnt significant lag between choosing a song and it playing i see no reason to use it
truz05
truz05
NY
Scoobydoo
