would you strongly recommend comps over coax?
Sometimes the difference isn't a lot.
You can have coaxially mounted components, so the line can be blurred //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif My Memphis Sync6's are a good example of that. They do have outboard crossovers and are running off ~100W per side, but the tweets are mounted in the center of the cone.
Crystal and Boston Acoustics make some coaxial speakers that come alive off proper power.
My friend is willing to sell me his 6.5 type r comps for 125.
but then id have to buy an amp..
amp wires... and im giong to assume that installation is goign to cost a hell of a lot more..
soooo im really questionnig if im willing to spend the money on it. Oh, and thyed probably be dramtically louder than my rear, so would I have to buy rear comps too to compensate?
You're going to need an amp if you want to listen at any appreciable volume without a lot of distortion //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Install the stuff yourself. It's not too difficult, especially if we help you along...those Type R components aren't too bad, although the tweets can be a little bright.
Don't worry about your rear speakers. You could even leave them stock if you want and run them off your head unit if you still feel a burning desire for rear fill. You want your front stage to be solid and defined, not the sound coming from in back of you.
christiankills
christiankills
Tampa, Fl
LoudCrownVic
