Would you do this?
86yota
OK heres my dilemma. 1st of all, I know I should get all matching VC subs, but im working with what I got. I have 4 12" D2s and 2 D4s. They are all wired to 1.6 ohm right now, but the problem is with box rise and what not, im gonna be at like 2 ohm, meaning Im limited to amps to do the power I need. Im wanting to run the new Crunch GP amps, and I was thinking about putting a 2500D on the 4 D2s (wired to 1 ohm), then the 1000 watt or 1500 watt on the 2 D4s (at 1 ohm). I would set the gains so that all 6 subs are receiving the same amount of power, or as close as possible, to prevent cancellation. How bad of an idea is this? The subs are all in a common chambered ported box.
why would there be any cancellation just because of two different amps? there wouldt be any cancellation. and why would you set both amps gains to the same? just set them with a dmm and be set. never heard of box rise, dont you mean impedance rise?
There will be cancellation if 2 different amps are used that give out different power as well as 2 different sets of vc config
this statement is not true and should be deleted so that it doesnt give others such false information
Yes impedence rise, its caused by the enclosure, and its often referred to as box rise. And it would be cancellation if all 6 subs are not getting equal power, say the 2 d4s are getting more power, they would be moving and being pushed differently. And in the same chamber, would cause cancellation
Terrible idea, you'll potentially damage the subwoofers, it won't sound too hot. I'd just try and sell the D2 subs and replace them with d4 subs.
If you have two amps powering subs that are all in a common chamber, you better use an o-scope or some other type of precision voltage measuring device to gain match those amps.
I have a Grand Marquis. 9 cube box, ported to 35hz, with 140sq of port area. So would my best bet to just be sell the d2s, buy more 4 d4s, and I beleive they will all wire down to 1 ohm? Right?
Dont tell me what will be louder or how to build my system, Ive had 4 12s, and 2 15s, and 3 10s, and 1 12, and now I want to do 6 12s. I asked about how to amp them, not how many I should own or install. Kthxbye. Thanks for the help so far guys, Im prolly just gonna resell and get 6 D4s.
86yota
86yota
Gat town, TN
Immacomputer
