Would this work?
you wouldnt be able to wire those subs down to a 1ohm load. So it would work if the amp can handle a .5 ohm load.
Umm...if you'd actually read what he wrote in POST #1 you would see that he was talking about Dual 2 Ohm subs (which easily wire to 1 Ohm with the coils in parallel) each being driven by its own amp......
kthxbye!
j/p....but seriously.....when I saw your post all I could say was "Why not?!"
well yah but we knew that u can make one 2ohm DVC sub at a ohm load but he wants 2 witch means that he will either need an amp that can handle a .5 ohm load or get 2 1ohm stable amps and run 1 amp per sub..... i dont think there is anyway posible to wire t 2ohmers down to 1 ohm
Please review the original post which began this thread ~ try and keep up now:
Would it work if I got 2 12' dual 2ohm D9's
Okay - he is talking about two separate Dual 2 Ohm subs which individually can be wired with the coils in parallel for a 1 Ohm load. Following so far?
and put each one on a D61000 which does 1000@ 1ohm?
Shall we review your post again? Nah, I didn't reckon it would be necessary....
j/p, mang //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
But c'mon, folks! Actually read every now and then maybe?
it would work indeed.
but....
maybe buy a single amp that does alot of power @ .5
IA 20.1 or Orion 2500d or something.
i dunno, it could save you some money...but i dotn know the cost of those Diamond amps.
ryanbssc29
ryanbssc29
Waveland, MS
ryanbssc29
vegang
vegang
