Would channels 3 & 4 likely have the same clipping point as channels 1 & 2?
nyg052003
I have the crescendo s800.4 and going to be running a polk 6.5 component set up front and in the rear 2 kenwood 6x8's in rear deck. I will run one 10 inch sub also. But in ref to or for my knowledge, I'm just wondering if channels 3 & 4 which will push the 6x8s and will be set after channels 1 & 2, I'm wondering if the clip points will be the same.
They should, if you're running the same input voltage to them.
cool.
I turned on my system for first time and adjusted everything monday and so far so good //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
cool.
Just be easy with it until you can check. If you run yours like I do, maxed out all the time, you might run your rears into light clipping if you tried to level match them with no multimeter.
yeah I think I went fairly easy with it.
as for my Hi's, the front stage ( Polk 6.5 comp set), it is about a halfway on gain while the rear is about a quarter of the way. And I actually set the gains for everything with volume on 35. Max volume is actually 62 so that is not even 3/4 of the max volume. I went up to 40 and no distortion. I will probably average playing it around 30-32 for most part but ofcourse there will be times it might see 40 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
definitely might take it to a shop though and let them put the tools on it since I don't have the tuning cd
You can download a tone generator app on your phone. Check out Xplicit audio calculator, I believe it's called.
I would give myself about 10 clicks on the HU and then tune it with a 0db tone and then check where you're at with a -5db tone. That'll give you your daily volume and your definite safe zone.
cool man sounds good. If I feel froggy I might just do myself //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In process of cleaning up garage from car project and gotta put a ceiling fan in the cave. Trying to knock stuff off to do list little by little ...
But I wouldn't mind doing it myself for sure //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
---------- Post added at 07:22 AM ---------- Previous post was at 07:21 AM ----------
cool sounds good
nyg052003
nyg052003
charleston, SC
nyg052003
