Worth the extra $ for higher preamp voltage???
rjay
So I am looking at two units; JVC KD-HDR70 or JVC Arsenal KD-AHD79, both are identical except for the preamp voltage. Arsenal has 5volts and other unit has 2.5volts. Only a $10 difference for the Arsenal unit, which I will prob go with. Is there a noticable difference with going with the higher voltage or not really? Only will be running a mono amp (Boston Acoustics 400m).
Higher voltage pre-outs are good for longer RCA runs and lower distortion. Since you don't have to crank your amp gains as high, you have less chance of noise. If the power is higher, it will drive a longer run of RCA's without needing more gain. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks for the info. I was going to go with the Arsenal unit anyways, since its only $10 higher, but I was just curious. Thanks again
No, but for 10 dollars why not.
audibly you wont notice any change
but your mind will constantly think
"what would it sound like if I had paid $10 more for the 5V"
trust me, ive been there. Its all in your head and it will drive you crazy
on high enough quality speakers you may notice more noise on a 2v than a 5v. and also, its nice to have 5v in the case that you need to use an RCA splitter because the voltage still stays reasonably high (>2v)
How are you going to hear noise from low preout voltage if you set your gain right?
Obviously a lot of people in this thread haven't played around with pre-amps and power amp gain settings....
Anytime you bump up your gain, you are amplifying more noise. Garbage in, garbage out.
Lets say you have a 15 foot run of RCA's from the front to the back and need to crank up your amp 3/4 of the way to match your front speakers. Usually you will hear a slight hiss. The noise floor is higher and sometimes the sound is compressed or squashed sounding.
Anyone who's played electric guitar or bass knows all about the noise associated with high gains, cheap cables (microphonics) and change in tone. Same subtle hints happen in car audio if you listen for it.
In short, there's a reason high quality HU's have 4-8V pre-outs verses the mainstream 1.5-2.5V outputs.
rjay
rjay
oklahoma city
Suicide Bobb
