r0llinlacs
One of my old school Eclipse aluminums took a crap the other day (I was extremely lucky enough to find another on craigslist the next day), the cone came detached from the coil. I tried re-gluing it with epoxy but it didn't last but for 5 minutes with medium volumes. The cone is damaged from the coil slamming against it and it had a catastrophic failure when it fell on concrete (never set the sub on the box while cutting the hole!) and busted the basket (repaired with JB weld). Now after further inspection I've noticed it might be missing some terminals and may actually be dual voice coil, but according to the model number it's single voice coil. Did they use DVC spiders on SVC models?
Is it worth saving, repairing/reconing? Worth selling? Or should I wall socket it? The coil is still good.
Cone damaged/bent
JB weld emergency basket repair, which worked amazing! JB weld is a life saver for certain tasks.
It broke right on a mounting hole. I still tightened a screw in that hole and the fix still held up fine.
The bad part.
Missing terminals? Or universal basket/spider?
88120.4 which I believe denotes single coil, DVCs would be 881202.4, my brother has one and that is the model number.
Cone damaged/bent
The bad part.
