Wood vs Metal Seals
Why So Cereal?
Invisible Cereal
I'm getting ready to go back and re-seal my doors for my new builld and I've been wondering about this for a minute now and figured now was as good a time as ever to ask
Would it be better to use wood or aluminum/sheet metal to seal the holes in the door frame? I know the wood is more rigid but is it really worth it over the metal? Basically, what do you guys use to seal your doors?
also, to those who have worked on a tC, will a piece of wood even fit in there? It seems like it might from the times I've been in there but I haven't looked into it too extensively.
you can deaden the steel but a flat piece of sheet metal is much harder to tame then a piece of ply wood. You can get more dead materials but unless your competing I'd just use wood.
Im probably gonna deaden the wood or metal whichever i choose anyway. What other materials were u thinking?
certain fiberboards and poly materials, but I doubt you will really hear much difference and it will cost well over double in price. especially on an area as large as a door opening.
Hey Prunc3cmo
Have you thought using a thin piece of plexiglass?
The TC doors isn't completely flat, so you will need something that can bend a little.
I didnt actually...hmmmm....Well the first time i used sheet metal and thats what another member on here used in his build log. So I dont think it'd be too bad for me to use it again. I'm thinking it'd be more rigid than the Plexiglass though....
I really would like to use wood this time though for the extra rigidity and less resonance. Unless of course it doesnt fit then I'll probably go sheet metal again. How would the Plexiglass compare to aluminum sheets performance wise?
Why So Cereal?
Invisible Cereal
Why So Cereal?
Drowning in milk
Why So Cereal?
michigan born
    May 14, 2026
michigan born
    May 14, 2026
