thats good sh*t, thanks broTwo articles on using RTA that you might find useful...
http://tinyurl.com/uq5n4
http://tinyurl.com/sbxmr
If the prolem is phase related, which is what you describe, ou will either needto adjust only one channel, mess with the placement/aiming/phasing (time alinment) of the drivers covering that freq. You can't fix cancellation with an EQ.I'd use a computer version. Heck, If I was going to the trouble of using a computer for tuning, I'd get MLS instead of a RTA. Much more tuning ability. 2 main things to remember when Eq'ing in a car using software. First off, find your dead areas. Some areas on your EQ will not respond directly to the EQ. A 2db increase on your EQ may not actually increase your RTA reading.
That's backwards, your description was right but that statement is wrong.it's almost always better to boost than cut.
A truly dead area in the freq response is never going to even respond to EQ. It's caused as I mentioned above by differing path lengths to the mic of drivers playig the same freq. Boosting those freqs just causes more amplifier powr to get acoucially cancelled out and increases the chance of clipping the amp ruining the response across the whole spectrum.dead area almost always needs to be tuned BY EAR.
Not sure what you meant hear, but the way it reads is exactly wrong. If it sounds bad to you then it is bad. Make it sound good to you. If you compete, you will probably need multiple EQ curves forthe various portions of the comp and then possibly another for your own personal enjoyment. if you don't compete, all that matters is that it sounds good to you. The RTA could show the curve from hell, but if it's what you like then it's all good.At the end of the day, if it sounds bad to you, it doesn't matter if you think it's correct, your not competing.
good stuffThe RTA could show the curve from hell, but if it's what you like then it's all good.
HAHA!
The RTA is a tool. It isn't the end all be all of system performance measurement. Like I said before, serious SQ competitiors would have two or more EQ curves set for the comp, one for RTA judging and one for listening, because a flat measuring car simply didn't sound natural. Before that practice became common, it was pretty standard for the car to be tuned to sound good at the expense of RTA score. The critical listening was worth more points so it was a tradeoff that made sense. As soon as someone realized that you could wire in 2 sets of AudioControl EQs and simply switch each one in or out of the signal path by pushing a button, it became common practice to do so.
If the prolem is phase related, which is what you describe, ou will either needto adjust only one channel, mess with the placement/aiming/phasing (time alinment) of the drivers covering that freq. You can't fix cancellation with an EQ. That's backwards, your description was right but that statement is wrong.A truly dead area in the freq response is never going to even respond to EQ. It's caused as I mentioned above by differing path lengths to the mic of drivers playig the same freq. Boosting those freqs just causes more amplifier powr to get acoucially cancelled out and increases the chance of clipping the amp ruining the response across the whole spectrum.Not sure what you meant hear, but the way it reads is exactly wrong. If it sounds bad to you then it is bad. Make it sound good to you. If you compete, you will probably need multiple EQ curves forthe various portions of the comp and then possibly another for your own personal enjoyment. if you don't compete, all that matters is that it sounds good to you. The RTA could show the curve from hell, but if it's what you like then it's all good.
Yes, it allows one to accurately simulate the sway that results from being really, really drunk... //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifThat's what I was trying to say, while posting when very, very drunk...
5.Slightly swirling the mic is still a good idea
http://www.avsforum.com/avs-vb/showthread.php?t=572477If you have a laptop or access to a laptop..
You can buy a Behringer ECM8000 mic ($47)
a Behringer UB802 to power it ($55)
and an RTA PROGRAM such as True RTA. Get the 1/6 octave version not because of the amount of bands, but because of the PC calibration feature, you will need this if you want an accurate reading. It takes any info that your laptop and mic are creating on their own out of the equation. ($69)
This is very accurate and cheap if you have a laptop. You will need a 1/8 jack to dual RCA connector and a mic cable as well.//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
When I used that tutorial, I misread it and bought both the external sound card (laptop sound cards are generally not of sufficient quality to get accurate readings) AND the mixing board. Now I have an unused mixing board. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gifIf you have a laptop or access to a laptop..
