Wiring
teenycar
Starting to look at wiring and figured I'd run by you guys what I was thinking to make sure I don't have problems. My thought is to run the speaker wiring down the driver's and passenger's sides of the truck. Then run the power wire for the amp down the driver's side close to the ***** tunnel or under the vehicle along the frame rail. Then run the RCA's down the passenger's side of the *****. tunnel. So what about the amp power wire from the head unit? What can it run with? Thanks.
I ALWAYS run the power wire on the same side as the battery....this keeps the power wire as short as possible ......I run my remote wire along side the power wire.......I run my rca's on the opposite side.......I run my speaker wires on the sides they are on left speaker ran down left side for example.
teenycar
teenycar
Redlands, Ca
boogeyman
