Wiring???
No i know how to run it, i just dont seee why you would need that much wire. You have a diagram?
do i have a diagram of my wire??? no bro just do some searchin. u figure i have 6 speakers up front so u have to run wire back to the amps, so 6 speaker runs from front to back in my truck is bout 20 feet so theres 120 feet right there
if you have a big enough system, you would need that much wire. It's mostly for SPL competitors Mr. SPLluminator
:rolleyes:lol, Yea ik splluminator is kindof a gay name. But thats besides the point. Im just saying, Im going to have a dd9512g and an IA 20.1 in my lumina for local SPL competition soon. I was planning on one run of 2/0 awg to the back. I know how to run wires, etc...
I guess im just having a hard time explaining. Ill put it this way. I got 110ft of 2/0 wire for a decent price. I plan on selling alot of it. Would there be an advantage to having more than one run to the back?
The cars with insane numbers of runs are usually running in a class that allows 1 battery. The multiple runs are there to get every bit of amperage possible from the single battery.
I have 2 runs of 2/0 to my battery bank in the rear of the truck.
Ok then ill do three runs. Where should i get a terminal that will alow that? or should i use just regular ring terminals on the battery terminal?
I have a dual terminal that tightens with an allen bolt, i got mine from an local electrical supply house. Havent seen a three lug type. You can stack standard lugs, or make a small buss bar and attach it to the battery then attach each cable to the buss bar.
SPLluminator
SPLluminator
GR, Michigan
DBBOOM
