Wiring x4 8-ohm and x2 4-ohm speakers to one amp
Im trying to wire x4 8-ohm 80w tweeters with x2 4-ohm 80w speakers into one amp, but i cant seem to figure out what the imdependance would be if I wire the tweeters in parallel, the speakers in parallel and then join the two ends together leading into the amp...
Im thinkin that...
x4 8-ohm tweeters in parallel would come out to 2-ohms
x2 4-ohm speakers in parallel would come out to 2-ohms
These two 2-ohm leads wired together would come out to 1-ohm.....does this seem correct?
Any help or advice is greatly appriciated, and I can upload a diagram of this ina bit.
[quote name='CrossoverOre']thats why I was asking. if its a 4ch he has a shot. if its a monoblock then he's F'ed[/QUOTE]
Yaaaaa... lol @Dontbehalen ; whats going on brotha cant help if you wont give us any input, as of right now tho you dont want to do this You will probably blow some isht up including your amp cause i doubt its 1 ohm stable.
Dontbehalen
Dontbehalen
Indianapolis
Loudmp5
