wiring up my nine.1
Pl8er
Can you solve it?
I have my nine.1 and my two 11ov.2's ready and I have them wired with + to - on each seperate coil and then the +'s both connected to the + on the terminal and the negatives all to the one negative. Now my question is do I just bridge the amp? The directions are not very helpful. This really sucks because I have it all sitting out and I'm not sure what to do. The amp has 4 speaker inputs, so thats where I am getting confused. The directions show to go plus to plus and negative to negative on each output...but I did the wiring inside the box as stated above.
Thanks.
Justin
if I have already wired the box up can I just run it to the one speaker connection?
Thanks so much for your reply...its driving me crazy that I can't plug it in because I can't plus the speaker cable in.
im not to familar with eD products are those subs dual 4?
hrm...I'm still confused.....let me see if I can find exactly what I did in a picture. It would be wiring option number 2 from your link. Now where do I plug the wires to the amp?
i dont understand what you mean by where to you plug them into the amp. you mean the speaker wire form the subs if so then to the speaker terminals
on each sub run 1 + to - on the oppisite voice coils then wire the + and the - on each sub that is open (has no wire in it) to the wireing terminal on your box then from that to the amp
Pl8er
Can you solve it?
Pl8er
Ahwatukee, Az
DaGh0st
