I got 2 re audio mt's, two orion 2500d's, 2 batteries and an iraggi HO alt. how should i wire all this up. im not sure how to wire from the batts to the alt, should i run one wire and then have a box that will split that to go to both batts?
not to knock you, but you have that equipment and you cant wire up your own stuff? better jus send it this way and in return i will make you a "How To" video for your next set upI got 2 re audio mt's, two orion 2500d's, 2 batteries and an iraggi HO alt. how should i wire all this up. im not sure how to wire from the batts to the alt, should i run one wire and then have a box that will split that to go to both batts?
after ya get ur alt in run a new wire (0awg with a fuse bigger than ur alt rating)I got 2 re audio mt's, two orion 2500d's, 2 batteries and an iraggi HO alt. how should i wire all this up. im not sure how to wire from the batts to the alt, should i run one wire and then have a box that will split that to go to both batts?
