Wiring up 2 amps...
Dunerider5
az
Im installing two a/b amps in a Ford F350 (two batteries), assuming I should run from one battery, im using 4 gauge to a D-block and 4 gauge to a 600rms amp and 8 gauge to a 200rms amp.
Question: What size fuse(s) do I use and do I put one before the block or one before each amp?
You should use one at the battery and one after the D-Block for each amp.
I would just add up the fuse total from the amps and use that (or a little higher if one isn't available in that exact size) and put that at the battery (as close as possible).
Then for the 2 coming off the d block use the amp rating from the individual amps. If one has two 25 a fuses then get a 50 amp fuse for the power wire.
Well I ended up ordering a kit that came with a mini anl 120A fuse. The total of the amps' fuses would be 90, so I guess Ill call and ask them to throw in a 90A fuse as well.
Thank you.
Thank you.
Negative. Stick with the 120 that they give you. Put that one under the hood. Once at the distro, fuse the 8awg leg anywhere from 50-80A. For the 4awg leg fuse it anywhere from 80-100A.
Dunerider5
Dunerider5
az
johnecon2001
BP1Fanatic
BP1Fanatic
