Wiring to 1 ohm?
Yeah tha only shows 2ohm, and .05 ohm not 1ohm? ANd does anyone know what the hell that guy was doing?
With TWO dual 2 subwoofers, you cannot achieve a 1 ohm final load. You can do 1 ohm PER sub on a 2 channel amp. But for a mono amp, the final load can only be 0.5 ohm, 2 ohm, and 8 ohm. Most amplifiers will NOT run at 0.5 ohm and if you try, will void their warranty. 8 ohms is too high and the amp will be fine but you won't be putting out any power. 2 ohms is your only option. You're looking at either a Kicker, Pioneer, Kenwood, or Alpine monoblock amp because they almost all rated @ 2 ohms. The person who told you a 1 ohm load can be achieved by wiring only 1 of the coils per sub is a retard and he is going to ultimately ruin your system.
Thank you Dnick. Thats what I have been waiting for all night, you anwsered my question instead of giving me a web site which I had already checked before i wrote on here. I am using a DB Drive Platinum 1200 which is 1 ohm stable, the way he hooked it up did not sound right. They hit but when I turned my bass on my eq they started cutting out. I guess he had them at .05 ohm? I did not understand I was dissapointed because the db plw are suppose to be much better than the rf p3 I have now.
Your best option would be to take the subs and wire their coils in series. That makes each sub have load of 4 ohms. Then take the subs and bridge them to the amp (in parallel) so that the subs have a final impedance on the amp of 2 ohms. Your amp will not be putting out FULL power. But your amp won't be going into protect mode.
86vette07
86vette07
san antonio tx
DNick454
