ok i had posted a ? on how to wire 3 subs to a two channel amp. heres some more detailed info.just would like some suggestions.
the subs are in different chambers. 3 total
heres the subs info.
SUBS
Subwoofer size 12"
Dual voice coil Yes
Voice coil design 4-Layer AVS Voice Coil
Basket design Info unavailable
Basket material Stamped steel
Woofer cone material KM3 Coated Paper
Woofer surround material PHAT foam
Fs - free air resonance (Hz) 37.4
Vas (liters) 69
xMax - maximum excursion (millimeters) 7
QTS .76
now i cant really wire them in paralle (sorry for spelling) due to the fact they are in closed chambers unless u guys know something i dont which chances are you do. heres the amps info. F.Y.I. its a sealed box.
AMP
Specifications
200 watts RMS x 2 at 4 ohms
400 watts RMS x 2 at 2 ohms
800 watts RMS x 1 at 4 ohms
stereo or bridged mono output
4-ohm stable in bridged mode
i want the best spl out of it. thanks
SUBS
Subwoofer size 12"
Dual voice coil Yes
Vas (liters) 69
QTS .76
AMP
Specifications
