wiring subs?
Do u think .25ohm load would be to much from the 40.1 daily?
It a Zenon board. The amps can burp down to .25 easily, but for music .5 would be ok for daily as long as you have a good charging system. But for you wiring, if you parallel all the coils on the sub it would bring the ohm load to .5 ohms per sub.
well, if your meter is correct, here is the list of causes. bad solder on the terminals, broken tinsel leads, bad terminals, bad solder between the voice coil and the tinsel leads, coil rubbing in the gap, blown coil. easy fix - buy a dual 2 recone.
Twank06"GTO'
Twank06"GTO'
houston tx
ultimate157
