wiring sub to amp through box
Speaker terminal.
yea i usaully drill a hole, tie the wire in a knot on the inside so you dont accidently pull the wire off the speaker terminals then silicone it up
edit- although a while back partsexpress had terminals on sale for about 50 cents I bought about 50 but havent used any yet lol
yeah, the bolts is what ive used, i havnt had any problems. try anyone of the suggestions, each work fine. or if you dont have a drill, just take the speaker wires and run them through the port to the amp if you have a ported box. it looks messy, but it will do.
drill a hole the size of the bolt, stick it through, put a nut on the outside and ighten it so there is a shaft left sticking out, then put the wire on with a ring and use another nut to tighten the wire. Use washers for the bolt head and nut that are against the wood.
I used carriage bolts through the box. Put a ring terminal on the inside of the box, push the carriage bolt through the box. Get a washer silicone the boxside of the washer, tighten down with a nut. I then put the ring terminal on the bolt and tightened down another nut. This allowed me to be able to take the box out when I needed to. Hope this helps.
ok how do you do the bolt one could you be more specific
get like a 1/4-20 bolt 3" long, drill a hole slightly smaller than 1/4" and screw it into the box. This will make sure it is air tight. Get two washers for each side of the box wall (to sandwich the wire) and a nut. Bolt everything tight.
A little hard to see, but here's what I did.
crunch5868
crunch5868
413, Massachusetts
J31Rob
