Wiring solobaric series or parallel?
kyleg94cavy
Stan Farrey is the man!
heres the scoup. i gotta 10" kicker solo. l5 4 ohm. hooked up to a profile 800 sx. the amp is 600 x 1 at 4 ohms bridged (that is rms) the kicker i have is 225 watts per coil adding up to a maximum of 900 watts how should i wire it up. may i also add that the amp is 2 channel and only bridgable to 4 ohms not 2! thx
Originally posted by kyleg94cavy heres the scoup. i gotta 10" kicker solo. l5 4 ohm. hooked up to a profile 800 sx. the amp is 600 x 1 at 4 ohms bridged (that is rms) the kicker i have is 225 watts per coil adding up to a maximum of 900 watts how should i wire it up. may i also add that the amp is 2 channel and only bridgable to 4 ohms not 2! thx
What do you mean 900watts/225 per coil? That would be 4 coils. Solos are dual voice coils not quad voice coils.....
what he's saying is that the driver is a dual 4 ohm driver, 225 RMS per coil, 550 WRMS total, with a peak rating of 900 watts...
the amp needs to be 2 ohm stable if its a d4 ohm driver...
Originally posted by Wonderbread what he's saying is that the driver is a dual 4 ohm driver, 225 RMS per coil, 550 WRMS total, with a peak rating of 900 watts...
Or, you can just wire it in series to 8 ohms and underpower the **** thang:D
kyleg94cavy
kyleg94cavy
Platteville, WI
Wonderbread
