Wiring RL-p Questions
beefy103
28
CT
Im now in the final stages of getting my setup up and running and had a couple last minute questions. So my rl-p is a dvc 4 and i know I have to wire the two postives together and the 2 negitives together into a 2 ohm load. My question is how exactly do I connect the two positives from each side into 1 wire? Or do i just connect both to the terminal? Also once I have them together do I just connect the positive and negitive the the a+ and a- on the amp. There are a+, a-, b+, b-. Do I just use one set? Finally I'm using 12 guage wire but do I need to use 12 guage inside the box directly from the speaker or just from the terminal to the amp? Can I connect the 2 positives and negitives with smaller guage? Thanks
use all the same gauge of wiring for connecting the sub. You can use a jumper from one VC to the other VC or you can run two lines (one from each VC). Depending on what your amp is (you didnt tell us), you probably can use both terminals. So you could run four pieces of wire to the amp. One from each lead on the VC's.
Consult your amplifier user manual
I have an eD Nine.1 amplifier. If I were to run 3 wires would it sttill be a 2 ohm load and what would I do for a terminal?
beefy103
beefy103
CT
beefy103
