wiring qusestion
cooper1513
ny
i have looked at diagrams of how to wire two 4 ohm svc subs to a mono amp to run the amp at two ohms. so, do you actually run the + and - speaker wires from the sub to the other subs wire, then to the amp or just each subs pair to the amp directly?
thanks
a simple little diagram:
so i am connecting the subs + and - from one sub to the other and then from that sub to the amp? what if i just connected both +'s and -'s to the amp directly, would it still be running at 2 ohms?
it should, but it's easier to just put 1 hole or terminal cup in your box, and run the wire inside.
cooper1513
cooper1513
ny
iceteebone
